No low beam
Old Dec 19, 2011 | 12:37 AM
Elec spark's Avatar
Elec spark
Default No low beam
Ok this is driving me nuts. I have a 2006 2500 diesel megacab. I had put some hids in and recently the drivers side quit working. You should know that the only way I could get them to work in the first place was to run my headlight switch on hi beam. Anyways I couldn't get the working again and ripped out the hid system. I went back to the oem system, and installed a new set of piaa bulbs. Now the hi's work, the daytime runners work, but only the passenger low works, and every once in a while, when switching to hi-beam, they don't respond. ( it's very dark when that happens ) I tested the voltage comparatively and found 12.54v on the passenger side, and 11.45v on the drivers. I'm getting a headache, please let me know.
Old Dec 19, 2011 | 06:34 AM
Cthulhu's Avatar
Cthulhu
I'm thinking you must have popped a fuse. High/DRL uses the same fillament witha lower watage output. I'm sure someone here will hep you find your fuse num.
Old Dec 19, 2011 | 03:29 PM
Caseys-dodge's Avatar
Caseys-dodge
Those voltage readings you posted were they for the low beam circuit or high beam circuit? I'm thinking 10 volts would still be plenty to light up the headlights. If there's power at the low beam plug on the driver's side but still no light, pull the working assembly from the passenger side and just plug it in to the driver's side to make sure it's not a problem with the bulb or housing.
Also check out the HID thread that's stickied at the top of the list. I know it's a really long one but lots of good info. Since you have an 06 it has the TIPM system and if the HIDs weren't installed correctly with the resistors the truck's computer might have permanently shut off the low beam circuit if it was detecting a fault on it for a long time.
Old Dec 19, 2011 | 04:05 PM
Elec spark's Avatar
Elec spark
Thanks for the info, is there anyway for me to reset the computer without going to the stealers
Old Dec 20, 2011 | 12:00 PM
Caseys-dodge
From all that I've read on here if the problem is due to the TIPM shutting down that circuit only a DRB/III aka StarScan tool can fix that - dealer only
