Mild lift
Old Dec 31, 2011 | 03:57 AM
detroitss's Avatar
detroitss
Default Mild lift
Well 08 Ram 1500 QC 4x4 Hemi. I have 20's with stock tires and truck still has stock suspension setup.
Since I just got the truck after it was turned to a dealer after a a lease I will be looking for tires. Truck has decent tires with a season plus of use still on them but I need some options. First if I go with just new tires on stock 20 rim. In this case which tire should I get or what is the biggest tire I can put in without any rubbing problem. I was looking at BFGoodrich rugged terrain.
Second choice is to put a mild lift. maybe life 3 inch or 4 inch. I dont want to hack anything up so do they make any decent bolt on mild lifts.
Third choice is to do a lift and 20's or 22's with off road tires but I need to hear how bad the ride is or how bad the road noise and MPG. Thanks.
Old Dec 31, 2011 | 07:13 AM
Xler8er's Avatar
Xler8er
If you go to the wheel and tire fitment on the top of 3rd gen ram section you should get a good idea what will fit or not fit.
A lift is always a plus if you want big tires..keep in mind when looking at lifts to make sure the stock back spacing will work..Im pretty sure most stock 20" rims work..If your not going with a lift and plan on wheelin your ride you might want to lose the 20s and get 17s because of the side walls. Do your homework it pays off. Hope all helps.
Old Dec 31, 2011 | 08:37 AM
HammerZ71's Avatar
HammerZ71
Lifting a truck - 101
