Finally did the TMR delete
Old Sep 17, 2012 | 07:23 PM
  #21
broggyr's Avatar
broggyr
Originally Posted by willdikem66
BTW there is a SCT tunner in the for sale section on here for 75, get your tunes from some one of your choice and you could get out for about 200
Hmmm. Now that's something to think about... Thanks
Old Sep 18, 2012 | 12:24 AM
  #22
Plainbroke's Avatar
Plainbroke
Default Worked on 02 also
Originally Posted by Owensue
It worked on my 02 also, with the 4.7 and 45rfe.
Hey can you post a picture of the wire you disconnected, mine freaked out when I tried doing this, so I figured I was pulling the wrong wire since I was getting trans codes.. I would love to get rid of the TMR it sucks in my opinion.
Old Sep 18, 2012 | 07:54 AM
  #23
broggyr's Avatar
broggyr
Here is the thread describing the procedure. Pictures start around page 3 I believe. This is only for 2002/2003 I think, 2004 and higher this does not apply. It's very easy to do, I did it in 10 minutes in the parking lot of work, and it is completely reversible if need be.
https://dodgeforum.com/forum/3rd-gen...elete-mod.html
Old Sep 18, 2012 | 09:50 AM
  #24
kenneymc's Avatar
kenneymc
Yellow wire with a light blue or green stripe. Can't remember stripe color for sure, but if you look on the side of the connector where the wires go in they will be numbered. It is pin # 10. Slowly work out the red "pin keeper". Encapsulates all pins on that end. Then work out pin 10. Tape it or heat shrink it once out. It is the pin on bottom row closest to the connector screw.
Old Sep 18, 2012 | 11:05 AM
  #25
willdikem66's Avatar
willdikem66
Its a green strip yellow wire, im sure he has already got this done by now though.
