4X4 Issue
Old Jan 6, 2012 | 09:17 AM
pl4life52's Avatar
pl4life52
Default 4X4 Issue
Ugghs I feel like this truck is giving me problem after problem. Makes me wanna get rid of it but i love it to much
yesterday I switched to 4x4 and i only went a few feet and it felt weird but i switched it back to 2 wheel and i was driving it i would get a shaking and it felt like one of the wheels was spinning and it would make a noise as if i was peeling out even though i was going straight at 30mph.
so today i tried it again switched to 4x4 drove a few feet i would get like whining noise and felt like it wasnt shifting so i put it back to 2 wheel and again had the isues with the tire screeching and vibration. so i read a little on hear saying to put it in reverse so "unbind" it so i tried that before work and still the same thing in 4x4 made whining noise and then like a clunking noise and when i went back to 2 wheel sound like every time i let off the pedal it would make like a clunk noise but when i go into 2 wheel and it makes that noise i would throw it in park and then it would be fine.
the way i shift into 4x4 is by putting it into neautral and shifting in 4 high. I did read on here to try going 1-2 mph and throwing it in but idk.
It is cold over here in NY now but i dont think it would effect it in those ways and few months back i used the 4x4 and it drove fine. I did change the diff fluid a few months back but 4x4 worked great after it i dont use it that much so i didnt use it after checking it after the change.
any input would be great, also i didnt use the 140 for dif fluid and i am going to be towing a boat this summer but only from the yard to the slip would i be ok doing this or should i change it to 140 gear oil its only a 18ft boat
Thanks
Jacek
Old Jan 6, 2012 | 12:54 PM
HammerZ71's Avatar
HammerZ71
Whoa there Jacek, what do you mean by 140 weight? Transfer case DOES NOT use a weighted differential fluid (ie. 75w-140 gear oil) but uses ATF +4 (automatic transmission fluid).
Therein lies your problem...
Old Jan 6, 2012 | 01:31 PM
pl4life52's Avatar
pl4life52
sorry made that a little confusing i did not use that in my transfer case i used 75-90 in my diff but i am going to tow a boat twice a year was wondering if thats ok or should i have gone with the 75-140
Old Jan 6, 2012 | 11:41 PM
dirtydog's Avatar
dirtydog
Moderate User
You'll be fine if the boat is on the lighter side and it's only twice a year. Hipefully you atleast used Synthetic as is req'd?
I have went from 2hi into 4hi at 55mph and back with no issue's. You need to be going very slow or in nuetral for 4lo engagement. You might have a bad 4wd select sensor???
4wd will whine a little if you are on bare pavement. 4hi should shift like normal, 4lo doesn't.
