Does anyones truck shut off sometimes when steering wheel is a full turn?
Old Jan 9, 2012 | 01:32 AM
vikingdiesel's Avatar
vikingdiesel
Default Does anyones truck shut off sometimes when steering wheel is a full turn?
Its happened about 2 or 3 times, sometimes if im in reverse and I have the steering wheel all the way to the right, truck will shut off. Anyone have this?
Old Jan 9, 2012 | 10:01 AM
boosted-fc3s's Avatar
boosted-fc3s
You don't say, your name says diesel, are you a gasser or a cummins? On a gasser a vac leak under load like full lock steering while not moving could cause a stall.
Old Jan 9, 2012 | 12:49 PM
vikingdiesel
yes, its a gasser, the 06 HEMI you see in my sig, so its OK then? yes, its pretty much while not moving or barely moving
Old Jan 9, 2012 | 01:14 PM
boosted-fc3s
Sorry I'm on the mobile version, it doesn't show signatures. Id look for a vacuum leak, maybe a disconnected hose. Does it idle at the correct rpm?
Old Jan 9, 2012 | 01:25 PM
boosted-fc3s
You could also have an air intake leak, or some idle control issues. The rpm should kick up a little when you turn the wheel and put some stress on the ps pump.
Old Jan 9, 2012 | 04:09 PM
KasperR34's Avatar
KasperR34
I've had this happen two times with mine as well:
Once in a snow storm, in 4WD reverse turned all the way to the right.
The second time in a rain storm sliding sideways with the wheel all the way right and the brakes locked up.
Keep in mind I have a stealthbox and all those damn lights on mine, so when it got surprised with the load of PS, Full ABS and every light I had on with sound system at full volume it stalled. Other than that, I've had no major problems with mine.
IMO, nothing to worry about. But let the pros give you the major advice
Old Jan 9, 2012 | 11:20 PM
vikingdiesel
NO vacuum leaks, if I did, check engine would be on. no CEL, no idle issues, this literally has happened twice in a matter of 5 months
Old Jan 9, 2012 | 11:37 PM
boosted-fc3s
No CEL doesn't necessarily mean no vac leak. Pull the vac line off the break booster and let it run for a while, there won't be a CEL. I've pulled the booster vac line to seafoam the truck. CEL never came on and it was running for quite a while.
