Torsion Bar Keys
Old Aug 5, 2005 | 12:40 AM
Phatboy's Avatar
Phatboy
Default Torsion Bar Keys
Okay, now that I am back in the 4x4 camp officially, I want to pick the front end of my truck up to level it and maybe run 285-70-17s.
I have read about torsion keys and have seen a couple of different ones. Are these better than just cranking the bars? I know that cranking will put your CV joints in a bind but how does the key alleviate this? Anyone have pics of theirs installed?
Where is the best place to pick them up from? Is there a need for new, longer, shocks? I think the bilsteins seem to be pretty good.
Here is a company that has them listed pretty reasonable.
http://www.generalspringkc.com/
Okay, I keep editing this post because I am looking stuff up. LOL. I have been reading that all the keys do is allow you to turn the torsion bars farther. I was under the impression that the keys themselves helped lift the vehicle.
Is anyone using keys?
Old Aug 5, 2005 | 10:46 AM
mpd2436's Avatar
mpd2436
Default RE: Torsion Bar Keys
Just installing my torsion keys gave me 1.5 to 2.0 inches of lift to my front end. I can adjust them for another 1.5 inches if I want to. The only problem I have is my stock shocks are topping out and need to be replaced. Only when hitting potholes though.
Old Aug 5, 2005 | 11:55 AM
tommiwan's Avatar
tommiwan
I have read a few guys who are running these. You will need longer shocks, especially if you ever take the thing off roading. Also I would recommend going with some bigger tires especially if you are getting 2-3 inches lifted in the front. I can fit 305's without lifting or cranking the front, so if you did lift/crank you could fit 315's. It looks good to have that wheel well filled up.
http://www.truxxx.com/dodge_products...m_lift_kit.htm
Old Aug 5, 2005 | 06:26 PM
Phatboy's Avatar
Phatboy
Thanks for the info guys.
MPD- are your torsion bars still uncrunk? I am just curious about the CV axel angle. I am hoping the Keys eliminate the rack and pinoin wear that I have been reading about with the torsion bars turned up.
I think the 285s would be cool, 33s or so, I pull a camper and I dont want to throw off the ratio too much. Plus much bigger would probably put a huge damper on mileage.
That truck looks good on that site. The price is a bit higher than I have seen. The one from KC was around 165.00.
Any alignment problems with the keys?
<edit> Im sorry they have them for 85.00
http://levelingkits.generalspringkc....getorsion.html
Old Aug 6, 2005 | 12:38 PM
mpd2436's Avatar
mpd2436
I just ordered my shocks so when they come in I will adjust the torsion bars for a little more lift in the front. I decided to go with torsion keys because I didn't want a rougher ride by cranking up the torsion bars too far. Right now my truck rides the same as it did before I put them on. Once I raise another 3/4 of an inch I don't see that changing the ride quality much at all. I'll let you know when I finish it.
Old Aug 6, 2005 | 12:42 PM
mpd2436's Avatar
mpd2436
By the way i'm going with 33's on 17" rims once I do the final adjustment. I like the look of stock rims but want the bigger tires in All terrains. The All Terrains for 20' rims are just too damn expensive.
Old Aug 6, 2005 | 02:09 PM
05_black_beast's Avatar
05_black_beast
ORIGINAL: mpd2436
Mine seem like they are topped out from the factory? [sm=wtf.gif]
I think my truck only needs about a 1/2" - 3/4" lift in the front to be where I want it. So Going a couple turns on the stockers should be my best bet, right?
Old Aug 6, 2005 | 07:07 PM
Phatboy's Avatar
Phatboy
I think the 33s will look great. Thats what I am planning on. Then once we sell our camper and get a motor home, then I am going to throw on a 3in body lift and 35s. Did you put the torsion keys on yourself?
I want to level it out but I dont want any adverse effects,
Old Aug 7, 2005 | 03:19 AM
mpd2436's Avatar
mpd2436
No I had a local shop do it. They had the lift and the right tools. I also had them align my truck. I haven't had any problems at all since the install,(aside from the shocks topping out). I just received my front shocks today, just waiting on the rears now. I figured I would replace all of them at once.
Old Aug 7, 2005 | 03:26 AM
mpd2436's Avatar
mpd2436
Black beast your shocks shouldn't be topping out if your at the stock ride height right now. If you only need a 1/2 to 3/4 of an inch lift to level your truck you probably could adjust your torsion bars a few turns without losing ride quality. I needed 2 to 2.5 inches in the front to level mine. That's why I went with the torsion keys.
