CV Angle or stub shaft issues??? ahhh
Old Jan 12, 2012 | 10:22 PM
cam_toews3's Avatar
cam_toews3
Default CV Angle or stub shaft issues??? ahhh
03 Ram 1500
So i just spent $1400 at a driveline shop replacing both stub shafts and two new front axles. I'm completly unhappy with the work because im getting a grinding or ticking noise when i turn at a slow speed. Would that be the cv's or the stub and axle not spinning together and therefore griding?
The truck does have a leveling kit on it. I had my mechanic install it 2 years ago and had no problems until a month ago. I'm wondering what is the typical ride height for the front of the vehicle (bottom of wheel to fender well). Here is a picture of the cv angle with the truck on flat ground and wheels straight.
I just had new tires installed 275/65/20 so they are 34" tall (goodyear duratracs great tire by the way.)
Uploaded with ImageShack.us
Does this look okay? How can i measure the angle of the cv? could i just put a digital level on the shaft between the two joints?
I installed longer shocks but the driveline shop says they are too long and if ever extend fully i will bind my axles and snap them. I know they are ranchos but i can't remember the exact model i will try and find out though.
Old Jan 13, 2012 | 08:27 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
angle doesnt look bad compared to other pics Ive seen but someone with a 4wd can better answer. Have you lifted the front end and spun the tire by hand to see if you can duplicate the sound?
Old Jan 16, 2012 | 10:55 PM
Chris1530's Avatar
Chris1530
angle dont look bad at all to me...
Have you checked the hub (wheel) bearings ?
Old Jan 31, 2012 | 09:03 AM
cooper.chris313's Avatar
cooper.chris313
clicking is usually CV joint. Grinding is usually wheel bearing. If you only get grinding on turns, and since your CV's are new, could your rims be rubbing something when turning? Possible it is a dust shield too. For $1400 you should take it back to have them verify everything is right. You should have a warranty.
Old Jun 2, 2013 | 12:55 PM
cam_toews3's Avatar
cam_toews3
I know this is a late reply and i completly forgot about this after i took the truck in for an alignment. And yest i did take it back to the driveline shop and they told me nothing was wrong or they couldnt hear the issue. It turned out for some reason the driveline shop had loosened the steering shaft (not sure what to call it) anyways my alignment guy had it figured out in 15 minutes and all fixed up.
