Which leveling kit to go with?
Old Jan 16, 2012 | 05:53 PM
Arctodus's Avatar
Arctodus
Slackjaw, we have the exact same truck. The reason I endorsed the Hell Bent is because I was able to lift my truck for $80.00. The exact same lift with other companies is $225.00. Big difference. If you only go 2.5" or less you can even keep the same shocks although I replaced mine with Bilsteins which ride soo much better than stock.
Old Jan 16, 2012 | 08:14 PM
Folkmantis's Avatar
Folkmantis
I am also planning on leveling my 2002 4x4 reg cab, I was planning on just cranking the stock keys up to level, which is 2 inches. I was mainly wondering if I need to replace my front shocks or not. I don't mind it, mainly because a leveling kit is 120 or so, and new shocks for the front is 100, so new shocks or not I'm happy.
Old Jan 16, 2012 | 08:25 PM
HammerZ71's Avatar
HammerZ71
Get the shocks (or at least relocation brackets for your existing ones), you can "get by" with the stock shocks but the over-extending will shorten the life considerably and they may bottom out at times...
Old Jan 16, 2012 | 10:15 PM
Eisengott's Avatar
Eisengott
Is there a DIY for turning the torsion keys on a 06 4x4 or anything similar?
Old Jan 16, 2012 | 11:55 PM
Brandon Anderson's Avatar
Brandon Anderson
As stated by Hammer earlier in this very thread, only '02-05 4x4 have the torsion bars. For an '06, your best bet is the Bilstein leveling struts.
