Rearend pic - anything about this say LSD or not?
Still having a hard time with the LSD thing. I have no documentation that explicitly says I have LSD or anti-spin, as I've posted several times before, but have been told by a couple of people here that I most likely do. Nobody ever answered my question about whether or not one can tell by just looking at it. In case someone can, here's a pic of what's in there.
Cannot tell by that pic. You need to take a pic looking into the ring gear. In the middle of the ring gear, you can see clutch plates. There's also little openings on the left side(backside) of the ring gear whereyou can see if there's w-shaped clips that hold the clutch packs in place. Pic on the inside is best for us. So, step to the right and angle the camera to the left inside the ring gear..hope that helps?
I've posted a couple times before but for this thread's posterity, I'll show it again. Below is a pic of my glove box sticker, followed by all of the D codes on my build sheet.
DGESAll 5-Speed Automatic Transmissions
DGQ5-Spd Automatic 545RFE Transmission
DHAPLock-Up Torque Converter
DH5Elec Shift-on-the-Fly P/Time T/Case
DJMS205MM HD Front Axle
DMH3.92 Rear Axle Ratio
DRBSCorporate 9.25 LD Rear Axle
Trending Topics
Yeh, um - No. I'd like to keep my stuff in one piece for a few more years. I gave the burned rubber up many moons ago.
I do know that I often have trouble jumping on the gas from a dead stop when there is a misty rain going on and I only feel 1 wheel spinning. Weird thing is, this truck has always handled mud and snow just fine. However, it's usually in 4-hi in those conditions.
