Overheating
Update
guys,
FINALLY got her fixed!!!!!
quick run down.....
old water pump was "squeakin", bad bearing
put new water pump on
started running HOT, never ran hot before
changed thermostat, which was the most expensive thermo EVER..
still ran hot.
checkd forums and tried all that was suggested...
threatened truck w/ a stick of dynomite..
pulled thermo out to run w/o it... won't work, leaks like crazy...
drained all fluid and filled again...
TEMP finally regulated normally.... hallelujiah.....
guess it had something to do w/ the "air" in the system or something...
THANKS for all the help and concerns....
til next time....
quick run down.....
still ran hot.
til next time....
