2002 1500 AC/Heater blower only runs on high speed
Old Feb 16, 2012 | 10:30 AM
starneml's Avatar
starneml
Default 2002 1500 AC/Heater blower only runs on high speed
Hoping someone can point me in the right direction.....
I have a 2002 1500 SLT with the diver/passenger dual AC/heater control.
One day, it just stopped. I discovered that it works on the highest setting (heat and A/C both) but will not run on the lower settings.
Could this be a relay? or the control panel (a new control panel is over $200 so I am hoping its something more simple.
Anyone have any suggestions on how to check it out?
Thanks
Mark
Old Feb 16, 2012 | 05:34 PM
Magnum4406's Avatar
Magnum4406
Most likely your blower motor resister is bad. I have had to replace the resister and harness pigtail on my wife's Durango. The resister is about 15 bucks or less, the pigtail is where they get you...I think around 60 bucks and you have to assemble it!!!
Old Feb 16, 2012 | 05:51 PM
dirtydog's Avatar
dirtydog
Moderate User
Yep. Above is correct.
Old Feb 16, 2012 | 07:36 PM
NoLimitzR1's Avatar
NoLimitzR1
I just had to do this for a buddies ram you can get whole thing for 40 to 50 online.
Old May 2, 2012 | 09:43 AM
uponone's Avatar
uponone
First try the connect uner the glove box (right above where your feet are) on the passenger side. There is a pug/connection that can come loose, if its unpluged, your fan will only run on high. Sometimes it gets kicked by people's feet...check it out first.
Old May 2, 2012 | 11:34 AM
Ellis42's Avatar
Ellis42
+1 on resister
It's an easy fix, I was going to do it on my wife's car(01 impala) but she said she don't mind it only working on high so I guess I'll leave it alone for now
Old May 2, 2012 | 01:37 PM
dirtydog's Avatar
dirtydog
Moderate User
I'm sure he has fixed it by now. Too bad he post and left without any updates...typical.
Old May 2, 2012 | 05:13 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I wuld have voted on the resistor also. But dont you just hate it when guys come and as all these Qs bc they have issues and never stick around or report back? UGH!
Old Jun 9, 2012 | 08:02 PM
atvtrailer's Avatar
atvtrailer
I have a 96 ram 1500 sport 4x4 with the same issue. First setting stopped and then a few days later it now only works on high. Anyone have any places or links of places to get the parts.
Old Jun 9, 2012 | 08:35 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You need a new resistor bock and you can get it at your local auto parts store
http://www.autozone.com/autozone/par...362031_0_3330_
http://www.autozone.com/autozone/par...er=358843_0_0_
http://www.autozone.com/autozone/par...er=901557_0_0_
