best diff fluid front and back and transfer case fluid
Old Mar 3, 2012 | 07:24 PM
rem300wsm's Avatar
rem300wsm
Default best diff fluid front and back and transfer case fluid
Whats the best fluid for front and back and for transfer case for dodge 2007 2500 5.7 quad cab and i want the most synthetic for all. Thanks.
Old Mar 3, 2012 | 09:55 PM
jj141979's Avatar
jj141979
Royal Purple is about as good as you can get.
Old Mar 3, 2012 | 10:50 PM
NV290's Avatar
NV290
Actually, a review was just posted and Royal Purple was not the best. Mobil 1 was rated higher. Ill look for the link.
Old Mar 3, 2012 | 10:57 PM
NV290's Avatar
NV290
Here is a link to the review:
http://www.syntheticoilhq.com/pdf/g2...comparison.pdf
Mobil 1, Valvoline or Royal Purple are all fine. Just follow the service schedule and you will never have any issues. Thier is absolutley no reason to pay more for one top brand over another because you think you are getting better protection. Buy whatever brand that scored high is priced best. You are not getting better protection because you pay a few bucks more.
Old Mar 4, 2012 | 12:04 AM
rem300wsm's Avatar
rem300wsm
my truck has 62 000km on it is it worth changing all these fluids thanks
Old Mar 4, 2012 | 05:05 AM
Dudemanbrother's Avatar
Dudemanbrother
Yes. They should be changed every 24,000km. Be sure to remove the covers and inspect the teeth, c clips, and clean the magnets, especially if it's the first time it's been changed. Any small metal shavings from production are sitting in there now.
Old Mar 4, 2012 | 07:26 AM
HammerZ71's Avatar
HammerZ71
I've read this one and can also Google up other ones that show RP is the best, can pull up some that show Mobil 1 is the best. First of all, AMSOIL ran the tests and I don't put too much stock in a test conducted by one of the contestants. Also, Amsoil's largest competition in HIGH END lubrication is Royal Purple, so I'm not surprised RP had such a poor showing. Mobil 1 is kinda your "common man's synthetic" but the real performance gurus tend to lean towards RP or Amsoil.
Not that I'm touting RP. I really don't think you can go wrong with ANY name brand lubricant as long as it's changed at proper intervals. I run Lucas HD conventional in the rear - as my Auburn LSD specs a conventional must be used for proper operation and I run RP in the front, but I wouldn't hesitate to run Valvoline or Mobil 1 either...
Old Mar 4, 2012 | 11:17 AM
rem300wsm's Avatar
rem300wsm
What are the magnets, and where are they, and clean them with what. Thanks
Old Mar 4, 2012 | 11:53 AM
NV290's Avatar
NV290
At the bottom of each Diff housing is a small magnet. You can wipe it off with a rag to clean it. Just look for any large pieces of metal.
Old Mar 4, 2012 | 06:44 PM
MikeHTally's Avatar
MikeHTally
Clean it with brake cleaner and a few rags.
