Steering feels strange for about 3 days?
Old Mar 28, 2012 | 05:35 PM
arch-stanton's Avatar
arch-stanton
Originally Posted by Train
I just went through this. The mechanic I used replaced the steering shock and the problem has disappeared. At the same time the steering problem started, it also developed the "Death Wobble".
What problem did you have? I cant imagine the steering stabalizer would fix my problem
Old Mar 28, 2012 | 08:58 PM
Train's Avatar
Train
Same kind of feeling. Kind of tight and when you straightened it out by letting the steering wheel slide through you hand it was kind of jerky. Most noticeably at low speed. The old shock was leaking really bad though.
Old Mar 29, 2012 | 08:32 PM
arch-stanton
It almost seems we have the same issue. My shock is not leaking though. Why would that make it so stiff I would think loose??
Joe
Old Mar 30, 2012 | 03:19 PM
hillbilli's Avatar
hillbilli
Is there resistance all the time when turning? Is the resistance greater or lighter when on differant types of surface such as harder to turn on pavement but easier on gravel? When it is hard to turn, try giving it a touch of throttle to raise the rpm's. Is it easier to turn with the higher rpm's?
Old Apr 8, 2012 | 10:51 AM
arch-stanton
Replaced the gear box yesterday and that fixed the problem. Although now the steering is 1/4 turn more to the right than left. Also the steering wheel is cocked right now as well. I know the pitman arm is in the right spot but should I turn the gear box link? I would need to get an 1/8 of a turn on the spline not sure if the flats on the spline will line up with that small of a turn.
Joe
