Transmission slam
Old Mar 11, 2012 | 08:21 PM
Scff's Avatar
Scff
Default Transmission slam
2007 Ram 1500 quad cab with a Hemi. Every so often after I back up, when I put it into drive, it jolts a little. Feels as if I was rearended. The fluid level is fine. Any suggestions on what it could be? Is it normal or is it a common problem? Thanks
Old Mar 12, 2012 | 12:07 PM
scwpd's Avatar
scwpd
Have you had the trans flushed lately?
Old Mar 12, 2012 | 04:52 PM
Scff's Avatar
Scff
No. It has 55,000 on it. Doesn't call for a trans service until around 64,000. I was planning on changing the trans fluid and filters.
Old Mar 12, 2012 | 06:05 PM
Kscha41's Avatar
Kscha41
My 04 has done that since the day I bought it used over two years ago. I have changed the fluid and filters and it didn't change anything. I notice that if I don't stop all the way and shift it into drive, I get no slam, but it I stop all the way, then I shift it into drive, I get the slam.
