3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
so i got the code..i replaced the 02 sensor..only 2 on my exhaust one up and one down stream...and i still have the code..the truck idles alittle funny but other than that its fine..its a 03 ram 1500 hemi 5.7 2wd..what could it be guys?
Unplug the sensor and using a voltmeter check voltage on the signal wire harness side. If voltage is present with the sensor unplugged and key on then the wire is shorted to somewhere.
