Old Aug 10, 2015, 02:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Strange turn signal issue
Old Mar 25, 2012 | 10:22 AM
MikeHTally's Avatar
MikeHTally
No flasher in the traditional sense. It's integrated into the cluster.
Old Mar 25, 2012 | 11:38 AM
fewmopar's Avatar
fewmopar
I have a 06 Ram and went to the dealer and he said yes about the recall and I asked how long it would take to fix it he said about half a hour because they don't replace the whole switch assy all the do is replace a part in the switch on your truck. Has anybody else been told that and has that worked out ok?
Old Mar 26, 2012 | 09:37 AM
DodgeCares's Avatar
DodgeCares
Few,
Here is the exact bulletin as posted by Chrysler on the issue.
NUMBER: 08-002-12
GROUP: Electrical
DATE: January 13, 2012
SUBJECT:
Multifunction Switch Malfunction - X42 (10 Year Or 150,000 Mile (240,000 Kilometers)
Warranty Extension)
OVERVIEW:
This bulletin involves replacing the multifunction switch if found inoperative or operating
incorrectly.
MODELS:
2006 DR Ram Pickup 1500
2006 DH Ram Pickup 2500
SYMPTOM/CONDITION:
Some customers may experience a turn signal switch malfunction that will cause the turn
signals to flash incorrectly. When selecting a right turn, the left flashers will function and
when selecting a left turn, the right flashers will function.
DIAGNOSIS:
If the multifunction switch is found malfunctioning, Perform the Repair Procedure.
NOTE: This Service Bulletin only applies to the replacement of the Multifunction
Switch. All other repairs are not overed by this Service Bulletin.
PARTS REQUIRED:
Qty. Part No. Description
1 CNH3X200AA Switch, Multifunction
REPAIR PROCEDURE:
NOTE: Procedures to replace the Multifunction Switch have been revised to remove
/ install switch from bracket as compared to replacing the assembly. Steering
wheel removal is no longer required.
Old Mar 28, 2012 | 09:57 PM
JMB3384's Avatar
JMB3384
I got a recall letter about a month or two ago about my 06 having flasher problems. I guess from what the letter said is the blinkers on the dash would flash opposite sides and could cause disfunction outside as well. I didnt experience the problem and I dont remember what the years were but you should call a dealership with your vin#. Have them run it and see what recalls you may have and what was fixed or not. Just a thought!
Old Mar 29, 2012 | 07:34 AM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by bam344
I had a similar problem a couple times. When I would turn on, for instance, my left turn signal the indicator light would be for the right turn signal. The problem for me was the multiposition switch. I've had to replace it twice now.
This is a multifunction switch issue.
Originally Posted by slakker25rs
maybe it might be the flasher?
The flasher relay is what operates the bulbs, so the bulbs should flash in accordance to the flasher relay. If the flasher relay is at fault, the lights wouldn't flash and/or at an incorrect speed. You cannot have a flasher that sends a single signal and have different outputs. Not possible. There is a difernent problem associated with this.
Originally Posted by notanexit7
Nice, at least mine isn't that bad. It only bothers me at night when I can see the bulb flashing and hear the indicator not matching it. I looked in the fuse panel but didn't see anything referring to turn signals so I might just try the switch then.
I would venture to guess you have a bad bulb, bad ground or a cluster related issue like a bad directional sensor. Not to be confused with the relay that controls the directional function itself.
