Old Aug 10, 2015, 02:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Strange turn signal issue
Old Mar 25, 2012 | 12:55 AM
notanexit7's Avatar
notanexit7
Default Strange turn signal issue
Hi, I've got an 04 1500 with a strange turn signal problem. All the bulbs are good but when I put the turn signal on, left and right, the turn signal bulb and the indicator lights in the dash do not match up. The indicator light in the dash seems to be blinking slightly faster than the bulbs are on the outside. It seems almost as if there's a ground wire loose somewhere or something but I'm kinda stumped.
Old Mar 25, 2012 | 01:40 AM
slakker25rs's Avatar
slakker25rs
maybe it might be the flasher?
Old Mar 25, 2012 | 03:06 AM
bam344's Avatar
bam344
I had a similar problem a couple times. When I would turn on, for instance, my left turn signal the indicator light would be for the right turn signal. The problem for me was the multiposition switch. I've had to replace it twice now.
Old Mar 25, 2012 | 04:02 AM
notanexit7's Avatar
notanexit7
Nice, at least mine isn't that bad. It only bothers me at night when I can see the bulb flashing and hear the indicator not matching it. I looked in the fuse panel but didn't see anything referring to turn signals so I might just try the switch then.
Old Mar 25, 2012 | 04:16 AM
MoparPaul's Avatar
MoparPaul
The multifunction switch problem was a 06 + issue I believe and quite expensive.
Plus you are experiencing different symptoms.
I would try a new flasher.
Old Mar 25, 2012 | 04:25 AM
MoparPaul's Avatar
MoparPaul
I hope you did not pay anything for both replacements.
Chrysler issued a extended warranty to 150,000 or 10 years.
NUMBER: 08-002-12
GROUP: Electrical
DATE: January 13, 2012
SUBJECT:
Multifunction Switch Malfunction - X42 (10 Year Or 150,000 Mile (240,000 Kilometers)
Warranty Extension)
OVERVIEW:
This bulletin involves replacing the multifunction switch if found inoperative or operating
incorrectly.
MODELS:
2006 DR RamPickup 1500
2006 DH Ram Pickup 2500
SYMPTOM/CONDITION:
Some customers may experience a turn signal switch malfunction that will cause the turn
signals to flash incorrectly. When selecting a right turn, the left flashers will function and
when selecting a left turn, the right flashers will function.
DIAGNOSIS:
If the multifunction switch is found malfunctioning, Perform the Repair Procedure.
NOTE: This Service Bulletin only applies to the replacement of the Multifunction
Switch. All other repairs are not overed by this Service Bulletin. __________________
Old Mar 25, 2012 | 04:28 AM
notanexit7's Avatar
notanexit7
I didn't think these trucks had a flasher relay on them, just a power module thing. At least, that's what I've read.
Old Mar 25, 2012 | 04:45 AM
MoparPaul's Avatar
MoparPaul
I'm not sure you have a problem at all...
Pretty sure there isn't a mechanical flasher anymore. The electronics are nice enough to give you an artificial click sound, though.
I believe the "click" is generated separately from the flasher function,
park in front of a garage door/wall and put your turn signal on, if you watch the reflection off the wall you'll notice the flashing and the "click" aren't in phase.
That's just the way it is...isn't new technology wonderful?
Old Mar 25, 2012 | 04:49 AM
notanexit7's Avatar
notanexit7
I did. The flashing arrow and click in the dashboard are the same speed. The bulbs don't match up. It's not a big deal but after reading about the fuse box failures in these trucks, I was just wondering if this was a sign.
Old Mar 25, 2012 | 04:59 AM
MoparPaul's Avatar
MoparPaul
I think your OK with your PCM.
