3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I was looking at buying a older dodge with some rust on the axle tube what would be the best way to take care of this cause the truck is a good deal and thats the only thing wrong well some other little rust here and there can you just sand it down and spray some rustoleum on it
I used a really stuff wire brush to remove any loose rust. I suggest you wear a mask so you dont breathe it all in. Rustoleum makes a primer for heavily rusted metal. It converts the rust, then just paint over with with some epoxy based paint or something sufficiently durable. The under-body parts rust, its just the nature of it. I actually really wouldn't be too worried about.
A flap disc on an angle grinder works great for removing rust in a hurry. Why are you worried about rust on the axle? Just looks?
If that's the case, I'd check for rust around the rear fenders, what little rust you find looking it over is generally just the tip of the rustberg
