Is this repairable?
Old Mar 29, 2012 | 02:06 PM
gHEMImorePower's Avatar
gHEMImorePower
Question Is this repairable?
If anyone read my recent thread about what happened to my bull bar, well here it is. I know it can be welded back together on the right side just fine, but the other is all bent and I'm not too sure if that's fixable. Please let me know if I should try and fix it or not even waste my time with it. Pics below:
sorry if the pics are huge, I didn't have time to resize.
Old Mar 29, 2012 | 02:23 PM
66three83's Avatar
66three83
If you can find a welder to do work on the side, It might be worth it. But generally from the damage I see, it might be cost effective not to mess with it, and just get a new one.
Old Mar 29, 2012 | 03:05 PM
gHEMImorePower
I can weld it myself, it's just the bent metal part idk about.
Old Mar 29, 2012 | 06:13 PM
Dudemanbrother's Avatar
Dudemanbrother
If you can weld then just get a small steel plate the same thickness and cut a new one, then weld it on. You can try sticking it in a vice and hammering it back into shape, but it'll probably leave a high spot or break.
Old Mar 29, 2012 | 07:04 PM
tantofolder's Avatar
tantofolder
I would use an oxy/acetalene torch to heat the bent piece and as mentioned, put it in a vice to straighten it.If you don't heat it the metal could be weakened by bending it back true.
Old Mar 29, 2012 | 07:07 PM
HammerZ71's Avatar
HammerZ71
I don't think you'd get it to look factory new again and looking at how paper thin that tubing is, it can't be very functional for protection. No sense in having a dinged up piece of decoration IMO. If it were mine, I'd toss it...
Old Mar 29, 2012 | 07:08 PM
RYCOMA79's Avatar
RYCOMA79
I agree fab up a new piece. cold working the metal will make it brittle and it will break again
Old Mar 29, 2012 | 08:28 PM
04HemiGreg's Avatar
04HemiGreg
Is that a watch or are you on house arrest?
Old Mar 29, 2012 | 08:32 PM
66three83's Avatar
66three83
Agree with Hammer, It's basically decoration, about as delicate as a glass ornament.
Old Mar 29, 2012 | 09:48 PM
gHEMImorePower
Lmfao!!!! That's my watch lol! And I'm thinking about tossing it, after that 4 hellas behind the grille? I don't think I'm skilled enough to make one
