Valve springs
Old Mar 29, 2012 | 03:50 PM
joebaum's Avatar
joebaum
Default Valve springs
Does my 9/03 dodges hemi have the weak springs , any idea how to find out . And if so do I replace them all with 6.1 exhaust springs ? Thanks for any and all help
Old Mar 29, 2012 | 05:00 PM
BCP Service's Avatar
BCP Service
Vacuum guage !! Should be steady at approx 18psi, if low vac or bounces around is sign of valve issue, test at idle and 1500 rpm.
Old Mar 29, 2012 | 05:25 PM
joebaum's Avatar
joebaum
No issues now but I would like to prepare for a spring replacment if nessesarry, thanks bcp, for response
Old Mar 29, 2012 | 05:34 PM
joebaum's Avatar
joebaum
More info it's a 2004 dodge qc 1500 4x4 5.7 hemi .
Production date of 9/ 03
I want to avoid the common so I read problem of broken valve springs on 03 hemi's .
Not sure if I need to worry, also if I do what make / model of 6.1 springs do I order? Thanks again !!!
Old Mar 29, 2012 | 06:28 PM
HemiLonestar's Avatar
HemiLonestar
I have about 120,000 on my original springs, which won't get replaced until I put in my cam. You will need 16 6.1 exhaust springs, these will replace your stock 5.7 intake and exhaust springs.
Old Mar 29, 2012 | 10:13 PM
joebaum's Avatar
joebaum
Are the 6.1 exhaust springs an upgrade even on 04 & up hemi ?
Old Mar 29, 2012 | 10:39 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Most guys you see with broken valve springs are on the 03/04s but thats not to say ALL 03/04s will have this issue.
(16) 6.1 exh springs will work on any 5.7 HEMI. I did a full cam swap thread in the FAQ that shows you how to change them if you want to do it yourself.
Old Mar 29, 2012 | 11:44 PM
HemiLonestar
