Tailights are annoying
Old Apr 26, 2012 | 06:55 PM
Deroneill's Avatar
Deroneill
Default Tailights are annoying
I've had problems with my tailights always giving me problems. Is there anything i can do to get rid of always having to change my bulbs out? I was thinking of going with some aftermarket LED's but i dont want to waste the money on them if theyre just gonna mess up too, but i'm hoping they could solve my problem
Old Apr 26, 2012 | 07:06 PM
MikeHTally's Avatar
MikeHTally
Do you know what's causing the lamps to fail? Are you sure they're failing? I've had my LED tails for five years or so, but you're right - if something's causing the failure, that's a risky experiment.
Old Apr 26, 2012 | 07:55 PM
NV290's Avatar
NV290
I just recently switched to LED tails last month. But prior to that, all my tail lights and headlights were original and working fine after 5+ years and 100k miles.
Did you have a moisture problem in your tail lights?
Old Apr 27, 2012 | 07:53 PM
dirtydog's Avatar
dirtydog
Moderate User
Your taillamp circuit boards are likely the issue. Common issue with them corroding.
I'm glad the 06+ tails dont have those circuit boards.
http://www.ebay.com/itm/02-03-04-06-...43bc8b&vxp=mtr
Old May 1, 2012 | 10:24 PM
blackram5.9's Avatar
blackram5.9
dirty dog is right circuit boards cost about $20 a side at slow reillys. pissed me off when mine went out used to laugh at my buddy with a chevrolet that had that problem.........cant believe dodge copied them
Old May 2, 2012 | 08:26 AM
Deroneill's Avatar
Deroneill
I changed out the whole taillight including the circuit board that came with it and the bulbs but I still get problems not even a
Month later. Sometimes the filament in the bulb from what I can see breaks off inside the bulb at that point I can hit the taillight and it knocks it back into place then it works. Kinda weird to me. Dang gremlins in my tail lights.
Old May 2, 2012 | 09:21 AM
dirtydog's Avatar
dirtydog
Moderate User
Sounds like a contact issue inside the socket. I just noticed my taillight wasnt working when I installed new ones. I took it off and when I moved the bulb around inside the socket it worked. I pulled it out, turned it around and it seemed to fit tighter and was getting much better contact. I squirt dielectric grease inside the socket before I put the bulb in place. Keeps away moisture and maintains good contact.
Old May 2, 2012 | 10:44 AM
hillbilli's Avatar
hillbilli
Try some dielectric grease and mabey a differant brand bulb. I think there might also be a PCM flash or something to correct the amperage to the taillights. But i think that usually works when the bulbs still works but throws a "lamp out" indicator. Its a buggy piece of equipment for something so simple...
Old May 3, 2012 | 09:11 AM
Deroneill's Avatar
Deroneill
Yea i'll try the dielectric grease and see if that helps. I guess sylvania bulbs just dont cut it
