truck is throwing a cel p0441
Old Aug 16, 2012 | 09:32 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Excellent resolution
Old Aug 17, 2012 | 10:05 AM
milkman82's Avatar
milkman82
Thanks for the diagram! I printed it out.
Ohh man I hope that stays what the problem is after seeing all those hoses! From what I understand though, it is typical for the vacuum boots or elbows on the canister to rot out and need to be replaced?
Old Aug 17, 2012 | 10:51 AM
ewing111's Avatar
ewing111
I don't know if I would say typical, but definitely not uncommon. It could potentially lead to one of those, fix the weakest link in the system and now the next weakest thing blows. Hope not for your sake but it happens. At least you can track down everything with that diagram. If you still have codes and can't find a visible leak/crack then you may have to get it smoke tested.
Old Aug 17, 2012 | 09:45 PM
milkman82's Avatar
milkman82
Yeah, that is a good point.
Where would I by the parts for the Evap lines that usually dry out and crack?
Is this a part at a local Advance Auto Parts or a dealer thing?
Old Aug 18, 2012 | 12:07 AM
willdikem66's Avatar
willdikem66
If you cant find the exact lines at a auto parts store then they could find a similiar one that may fit
