Does it need to warm up first?
Old May 16, 2012 | 10:56 AM
Dudemanbrother's Avatar
Dudemanbrother
Originally Posted by vengeancex
Thanks fellas, I'll surely do a drop and drain. I just googled the filter on autozone and it's a flat filter with a tube at the top and a spin on filter at the bottom of it. Sound about right? I'll just buy it and it see how it comes off and put it back on the same way. I heard that ATF - 4 burns the trans? You hear a lot from google. I don't know what to believe! Haha.
Your best bet is to buy the factory filters. A lot of fittment issues reported with aftermarket trans filters for 3rd gen. ATF+4 is what you have to use. It won't burn up the transmission, only failure to ever change it will, but that's like any oil in any truck. It has to be clean to help extract heat and lubricate. Otherwise **** burns up.
Old May 16, 2012 | 11:08 PM
Zoomin0074's Avatar
Zoomin0074
check this TSB http://dodgeram.info/tsb/2005/21-015-05.htm mine does the same thing and I know the trans was serviced.. I am thinking they put in the wrong filter.
