Muffler time....
Old May 27, 2012 | 01:02 PM
PRADO's Avatar
PRADO
90DB max limit in Cali. I don't like an open exhaust its too loud for me. just want a deeper tone.
Old May 27, 2012 | 06:19 PM
Rammin It's Avatar
Rammin It
I installed a Magnaflow 12641, 3" inlet,3" out. It is just about the same length as the stock muffler. Just had to turn the s-shaped pipe between the cat and the muffler 180 degrees. Sounds just as good as any dual exhaust I've heard.
Old May 28, 2012 | 12:18 AM
PRADO's Avatar
PRADO
S shaped pipe? Nice so that one pretty much just bolts on or did u have to have hangers welded too?
Old May 28, 2012 | 01:31 PM
Rammin It's Avatar
Rammin It
If I remember correctly, I just bolted it in, not as heavy as the stock one,So I didn't have hangers welded on.
Old May 28, 2012 | 03:01 PM
SLT8's Avatar
SLT8
Originally Posted by PRADO
Ya any mods b4 the cat without a carb sticker will fail the inspection part of.tje.smog
The y is after the cat if that helps..
Old May 28, 2012 | 03:50 PM
PRADO's Avatar
PRADO
I was talking about the y pipe in front of the cat. I always hear how restrictive it is. Wish I could change that but I dont want to deal with the failing inspection
Old May 28, 2012 | 04:42 PM
MoparPaul's Avatar
MoparPaul
Maybe I'm mistaken but I thought the Hemi engine factory exhaust consisted of:
2 cats coming off each manifold...
Coming together at the Y pipe and running down the rt side frame rail into the giant muffler, up over the rear axle and exiting behind the right rear.
2006+1500 Models w/ MDS had 1 or 2 resonators that have been mistakened for cats because of the placement of one right after the y pipe and b4 the giant muffler and the other one close to the end of the tail pipe.
But Cali trucks maybe different. I don't Know.
Old May 28, 2012 | 08:00 PM
08HEMI1500's Avatar
08HEMI1500
Yea the only Y pipe is after the cats. You're mistaking a cat for a resonator most likely.
Old May 29, 2012 | 10:49 AM
PRADO's Avatar
PRADO
Mines an 03 hemi its only got one cat and no resonators.
Old May 29, 2012 | 01:30 PM
08HEMI1500's Avatar
08HEMI1500
You're right and that cat is on the passenger side I believe? I'm not sure but I know it's before the Y pipe
