instrument cluster Help ASAP
Old May 27, 2012 | 11:41 AM
countryboy502ss's Avatar
countryboy502ss
Default instrument cluster Help ASAP
Truck: 2007 early Ram 2500 4x4
Problem:I was Replacing the lights in the instrument cluster with LED and everyting was going fine, well I cam to the part of taking the instrumnet cluster apart and I broke one of he gague needles, fuel to be exact. Well I was able to switch the guage motor behind the circuit board with the one for the voltmeter. I dont want to order a new cluster. I need to find where to order a needle and guage motor.
Thank you for you help
Old May 27, 2012 | 12:00 PM
boosted-fc3s's Avatar
boosted-fc3s
I don't think there is even a p/n for a needle. Junkyard cluster for donor parts?
Old May 27, 2012 | 08:08 PM
Dudemanbrother's Avatar
Dudemanbrother
The needle just pops on and off without replacing the motor. Junk yard is your best bet.
Old May 28, 2012 | 12:39 PM
countryboy502ss
is there a p/n for the motor??
and is the 2002-2008 needles and motors all the same
Old May 28, 2012 | 12:50 PM
dirtydog's Avatar
dirtydog
Moderate User
no part #'s for the stepper motors and as far as the clusters go, 2006-2008 should be the same. I know a few things on the inside changed after 2005 so not too sure if 2002.5-2005 motors will work???
