RPM tacho moving weird - 2006 1500 5.7 HEMI MDS 4x4
So I have a 2006 Dodge Ram 1500 ST. The 3.7L v6 with the 6 speed manual. And I have noticed that it drops down to about 300 at idle when the engine is still healthy at 600. No bogging or anything. So it’s not just the 5.7’s it’s all 06 1500’s. I haven’t tried to fix it because I don’t really feel like tearing apart my daily to fix something that doesn’t affect the way my truck drives. Since mine a manual I’ve noticed that when I take off and give it a little gas the needle pops back up where it’s suppose to be(I even red lined it to test it and it redlines at the correct rpm). I would like for there to be some kind of recall, if anyone has heard anything on a 100% fix that would be great so I can just drop it off at the dealership and know what I should be getting. I don’t want to take it there and spend $1000 on stuff I don’t need. Thank you.
HOW TO TEST FOR COMPUTER CODES:
HOW TO TEST GUAGES:
Few years back I temporarly fixed tacho issue with solution thrugh following video. Problem returned in half a year or so. I gues I din't melt solder enough and there I have cold solder crack again... I will try to send instrument unit to electrical specialist so he can perform better job on soldering two tacho chips.
