37x12.5-17 on a 17x7.5?
Old Jun 8, 2012 | 11:18 AM
ajtech81's Avatar
ajtech81
Default 37x12.5-17 on a 17x7.5?
hey guys i have a 03 2500 hemi 4x4 nv4500 with 4.56 gear and i like to have some 35x12.5-17 or better 37x12.5-17, my door sticker said i have 17x7.5, there are the steel chrome ones, u guys think i'm going to have any problems with the tires i'm trying to fit?
and will i gain mpg or lose with my nv4500 and 4.56?
how about performance?
Old Jun 8, 2012 | 02:26 PM
HammerZ71's Avatar
HammerZ71
Right on the border. "By the book" specs call for the wheel width to be 3" narrower than tire width with 1" -/+ being ok.
Prolly be fine unless you air down for off-roading where it'd be real easy to lose the bead...
Old Jun 8, 2012 | 02:31 PM
ajtech81's Avatar
ajtech81
i'm going more for 37x12.5-17 so it will fit fine?, no off-road only city/hwy, any pro and cons?, on the 37 how much air i have to fill?
i guess with my set-up im pretty god for the 37
you need a pics of the rims?.
thx for always replaying hammer!!!!
Old Jun 8, 2012 | 03:33 PM
08HEMI1500's Avatar
08HEMI1500
The tire should tell you how much air you need but like Hammer said you'll be cutting it close
Old Jun 8, 2012 | 03:40 PM
HammerZ71's Avatar
HammerZ71
Can you fit 37s? I know the SFA will handle it but doesn't a 2500 4x4 need 2" of lift height to just stuff 37s? I'm also not sure if the stock wheels have the offset needed for a 12.5" wide tire on a 2500.
Fuel economy you should gain a little because you are ridiculously overgeared right now, so you should overcome the added rolling resistance and weight - BUT those two factors will decrease performance from what you are getting now.
Old Jun 8, 2012 | 04:58 PM
08HEMI1500's Avatar
08HEMI1500
Yea 37s will definitely require a lift. 2500 4x4s can only fit up to 35s stock. And I'm not sure on the width but if they can fit 35x12.5s stock I don't see why it couldn't fit 37x12.5s. But I really don't know. If anything get spacers as a temp fix until you get wheels with better backspacing
Old Jun 8, 2012 | 05:52 PM
HammerZ71's Avatar
HammerZ71
Yeah, 12.5" wide is 12.5" wide regardless if the tire height is 33, 35 or 37".
I dunno about the wheel spacer deal though. I know guys run 'em, but I've seen one have the bolts shear off on a Nissan Frontier pickup, so I don't like 'em on a 1/2 ton truck much less a 3/4 ton.
IMO do it right or don't do it...
Old Jun 8, 2012 | 07:14 PM
ajtech81's Avatar
ajtech81
Ok at least with my nv4500 with 4.56 Ill be good performer , I least better than stock, Thx guys!
Old Jun 8, 2012 | 08:38 PM
HammerZ71's Avatar
HammerZ71
Without a doubt. There is a formula for calculating "Effective Gear Ratio" which is what your gear ratio is in relation to your tire size.
Stock, I had 3.92 gears and 31.5" tires. When I lifted and went to 35" tires my effective ratio dropped to 3.52. Re-gearing to 4.56 gears brought my effective ratio up to 4.10 which is still a higher ratio (more performance) than the stock setup was...
Old Jun 8, 2012 | 08:48 PM
ajtech81's Avatar
ajtech81
Yep that's y I'm heading for 37, I know if a get the 37x12.5-17 they going to rub like a 35x12.5-17 because the 2500 have plenty off room, I see I lot off guys running 37 on stock wheels with no lift and same rub on vs like a 35.
O got a email from a guy that have a 04 same model n the door said wheels are 17x7.5 but there are actually 17x8 as Chrysler made a typo.
