Front CV Axle****
Old Jun 19, 2012 | 10:56 PM
andrewdains's Avatar
andrewdains
Default Front CV Axle****
Im having a lot of difficulty getting my front CV axles off so I can change out the axle seals...any one have any tips on removing them?
Old Jun 20, 2012 | 01:21 AM
dakotatrevor's Avatar
dakotatrevor
Where are you having trouble? Are you using a pry bar to 'pop' them out of the diff?
Old Jun 20, 2012 | 10:59 AM
andrewdains
Yes, but they just wont budge.
Old Jun 20, 2012 | 01:50 PM
dakotatrevor
I'm assuming you've split the bottom ball joint, the only thing keeping the cv's in is right at the diff?
Sometimes they are really stubborn, I can't think of anything else that would be holding you up.
Old Jun 20, 2012 | 10:07 PM
andrewdains
Default Finally!
Took a hammer for the driver's side....and the passenger side...I had to pull the whole snub shaft out and hammer off the shaft....after I cut the boot off the axle....what a mess. Turns out that the snub shaft had a little rust on it, made it more of a problem to take it off.
