air condition blows hot when idle
Old Jul 6, 2012 | 06:43 PM
hillbilli's Avatar
hillbilli
Originally Posted by ljmjason
Hello everyone. My air condition in my 04 ram blows hot air when truck is idle but blow cold when driving down road. I thought freon was low so I put in a can yesterday but it still does the same thing. I noticed when putting in the freon, that the fan on the compressor comes on, but only stays on appr five seconds and then shuts off for appr 5 seconds before it comes on again. Dont imagine that is normal. Any ideas? New compressor or new fan? Thanks in advance. It be hot in this Louisiana heat
Are you talking about the fan cutting on and off or the compressor? Did you check the pressures before and after you put the can of freon in?
Lots of A/C questions here, check this out for some general guidlines
https://dodgeforum.com/forum/3rd-gen...diagnosis.html
Old Jul 6, 2012 | 08:29 PM
That1guy's Avatar
That1guy
I have to replace my fuse once every two years. It blows for no reason then its good to go.
Old Jul 9, 2012 | 07:57 PM
Chad2500's Avatar
Chad2500
Same issue, fan never moved, fuze looks good. Chances are fan is junk.
compared to wifes car, and her fan kicked on within 10 sec.
Old Jul 9, 2012 | 09:56 PM
meecrob28's Avatar
meecrob28
Heh, find it weird that I read this thread when it started and all of a sudden I had the same issue that very same day. Careful, it's contagious!
Anyway, could hear/see the clutch engage and disengage every five seconds or so. Checked the relay and fuses - all were good. Traced the issue to the condenser fan - it never engaged and don't think it has for a while to be honest! Jumpered 12V to the fan to make sure and it did nothing...
Took out the condenser fan and disassembled the fan motor.... The commutator was extremely worn with less than half of its original width left and the fan brushes were worn down almost to the wire! Sheesh! Ordered a brand new fan assembly on eBay for $55.
If it weren't for this thread/forum, I would have spent a lot more time diagnosing the issue so thanks to all that responded with suggestions! Hope the OP has made headway on the original issue!!
