Want to Increase my towing capacity
Old Jul 11, 2012 | 08:17 PM
Bowhunter2819's Avatar
Bowhunter2819
Default Want to Increase my towing capacity
Hey all I have the 1500MC which we all know is a HD chassis and 2500 suspension.
I want to increase my towing capacity. From all of you guru's what can i do to increase. Right now other then intake and exhaust im bone stock.
Old Jul 11, 2012 | 08:32 PM
MikeHTally's Avatar
MikeHTally
Towing capacity cannot be changed. It is what it is.
Old Jul 11, 2012 | 08:37 PM
Bowhunter2819
So new rears, axles, and springs wont help?
Old Jul 11, 2012 | 09:44 PM
66three83's Avatar
66three83
I also have a 2006 Mega Cab 1500. As far as I know, It has the 2500 chassis and running gear. The springs, however are not 3/4 ton. If it is badged a 1500, it has 1/2 ton springs. I have seen Mega Cabs with the 2500 badging, and they do sit higher than mine. If you want to increase your capacity, being that you already have a 3/4 ton chassis, you should be able to replace the leafs and front coils to achieve your goal. However, that is just my opinion, and I certainly am not a professional. Good Luck.
Old Jul 12, 2012 | 06:42 AM
MikeHTally's Avatar
MikeHTally
Well, if you put more than about 12,000# behind it and wreck it, neither the police nor your insurance company will want to hear how you increased the towing capacity. Plus, the running gear also has its limits.
Old Jul 13, 2012 | 09:39 PM
extremis's Avatar
extremis
Yup, no matter what you do the truck legally is supposed to only tow somewhere around 8500lbs. You can haul a payload of almost 2000lbs (including passengers, gear, and hitch weights etc)
As comparison my 2500 mega cab hemi, with 4.10 gears can tow up to 11000lbs, but only has a payload of about 2600lbs (not much higher than yours). Your 1500 megacab falls in the heavy duty half ton category due to its 3/4 ton chassis, problem is its 1/2 ton rated gears, diffs, brakes, axles and suspension limit its total towing capacity.
Upgrades may make it safer, handle better and tow better. But lawmen go by the sticker on the door and what the book says.
Old Jul 16, 2012 | 12:24 AM
natedoggsr71's Avatar
natedoggsr71
Ive seen that the 1500MC has 5 springs and the 1500 has 4. so it really seems like theirs no difference between the 1500 and 2500 unless the 2500 uses 3inch wide springs and the 1500 uses 2.5in.
Old Jul 17, 2012 | 12:04 PM
Yeti76's Avatar
Yeti76
If you need to tow more...you should prolly be looking to put your money into a 2500/3500 with the Cummins. I prefer to drive my 1500 with the Hemi on a daily basis but if you need to tear a building down you can't beat that diesel grunt.
