04 ram gear upgrade help!!!
Old Jul 15, 2012 | 12:02 AM
cuda1979's Avatar
cuda1979
Default 04 ram gear upgrade help!!!
Have a 04 ram 4x4 he I 390 gears will upgrading to 456 gears help me tow better wife bought a camper that puts me at 8200 loaded I know its to much can't afford to buy new truck right now pulls good up to 30 then has a hard time I work at a spring shop so suspension is not a problem what am I looking at for cost
Old Jul 15, 2012 | 12:07 AM
dlyter09's Avatar
dlyter09
Yes the 4.56's will help alot. Cost depends in your area and the shop. I could get mine done for $1200.. look around for a good 4x4 shop to do it
Old Jul 15, 2012 | 12:12 AM
HammerZ71's Avatar
HammerZ71
One local shop here charges $650 per axle. On the other end of the scale, the 4 Wheel Parts store about 45 minutes from me just quoted a guy I play golf with $2700 to regear his son's lifted F150. You'll probably find shops quote you anywhere between the two.
Also be aware that if you are towing over your truck's rated capacity and a passing cop suspects it, he can force you to a weigh station and at that point fine the **** out of you AND make you unhook and make arrangements to come get the trailer with a truck rated for the load.
Also of prime concern is that if you have an accident your insurance WILL deny any and all claims if they suspect you towing beyond capacity. It's possible if there is a large loss of property or severe injury or worse you could lose about everything you own.
Just a heads up...
Old Jul 15, 2012 | 01:07 PM
HammerZ71's Avatar
HammerZ71
Originally Posted by HammerHemi
Mine cost me $900 total front and rear.
You did GREAT!!!
I've had maybe half a dozen guys drive a couple of hours to use the shop local to me for $650 an axle because guys local to them were up over $2000 for front and rear gear jobs...
Old Jul 15, 2012 | 03:01 PM
hemi4109's Avatar
hemi4109
Going rate around here is anywhere from 1200-1800 per axle. Price of living somewhere where labour is 120/hr for specialized shops I guess.
Old Jul 16, 2012 | 12:18 AM
natedoggsr71's Avatar
natedoggsr71
Are you using a 4.7 or a Hemi?
Old Jul 17, 2012 | 12:04 PM
cuda1979's Avatar
cuda1979
its got the hemi with 390 gears im not looking to haul anything heavier and i dont want to kill it hauling feels like i have plenty of power just not enough gear, other question is will i burn the tranny up trying to pull for long distance
Old Jul 17, 2012 | 02:40 PM
cuda1979's Avatar
cuda1979
got some quotes close to 3 grand to get it done thats taking the truck in id rather put 3 grand down on a new truck thats crazy, anyone live around grand rapids mi that know of some places to go
Old Jul 17, 2012 | 02:42 PM
dlyter09's Avatar
dlyter09
Wow 3 grand is crazy.. if you were in PA i know a place thay would do it for 600 per axle
Old Jul 17, 2012 | 02:44 PM
WTFab's Avatar
WTFab
I pull a 22ft carhauler with 7k rated axles and load up my cj7 on one tons that weighs about 5k lbs. probably tips the scales around 7500-8000 lbs. I've towed it a bunch over the last 5 years with my 04 ram 1500 hemi 4x4 with 3.92 gears and 5 speed auto. It has plenty of power and stops it quick with trailer brakes. I would hate to see your RPMs going up a hill when it down shifts. Mine will rev up to over 5k sometimes but it has never once gotten hot on my and the only problem I've ever had with the tranny is a bad solenoid. Might be a little heave on the truck but I wouldn't go as far as putting in 4.56 gears unless you are running a 37" tire or something like that.
