need to know ABS Module / Ignition relation
Hi, My truck will crank but not fire up. Before I parked it I had flashing ABS BRAKE and AIRBAG lights followed with chimes... these lights came on and off only lasting about a second and sometimes just a quick flash. I see a fuse 35 I believe that is for ABS module and Ignition - ON... seems to be the problem but the fuse was fine, what else can I check?
Truck is not throwing codes, have tried spare key as well.
