3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Yes. Once you take the hub assembly apart the cv shaft will slide off. (the nut on the end by the hub took all day to get off) but you will see a c clip on the outer part of the shaft also
