Problem
Old Aug 22, 2012 | 04:41 PM
  #41
wingnutks's Avatar
wingnutks
Originally Posted by Gone Fishin
Nope, you'll see, just be careful
Will do.
And its ok to mix conventional and synthetic as long as you keep the same viscosity?
Old Aug 22, 2012 | 07:38 PM
  #42
Gone Fishin's Avatar
Gone Fishin
YuP! I used dino for the first 5K miles on minefor break in, then switched to synthetic, and never looked back-----I've been using nothing but synthetics for 30+ years for all my equipment that allowed it, never had a problem. Mabey thats why most industrial apps that require long term lubrication use synthetics--just follow the recommended viscosity ratings.
Old Aug 22, 2012 | 09:33 PM
  #43
wingnutks's Avatar
wingnutks
I just got back from the dealer, I was away from home the whole time the truck was in there so this was the first time I was able to speak in person to the mechanic. Good guy, an old school mechanic that went back to school so he could work at a dealership. When I got there he had my pan dropped, there was ALOT of crud in there, I was pretty amazed. He is cleaning it all out and will test drive the truck tonight.
He said when he had the motor apart the cylinders looked awesome for a truck with 90,000 miles, no carbon build up on the pistons or the valves. He also said the compression check was great and the leak down came back at 7%... I am guessing that is pretty good, he said "acceptable" was 25%
Old Aug 24, 2012 | 09:13 AM
  #44
wingnutks's Avatar
wingnutks
Truck is finally done, should be picking her up today.
Old Aug 24, 2012 | 04:29 PM
  #45
Gone Fishin
I hope they have it all worked out for ya
Old Aug 24, 2012 | 04:59 PM
  #46
wingnutks's Avatar
wingnutks
Just got home with her. Truck is driving good. Sounds a bit quieter. Idle is a touch rougher than I remember I think, might just be because the ECU only has < 5 miles on it and has had not enough time to adjust. Or I am just remembering wrong.
Gunna do front/rear diff fluid, tranny fluid, and front brakes rotors this weekend.
Old Aug 25, 2012 | 08:42 AM
  #47
Gone Fishin
Heads up on the brakes, Wagner just released a new pad that eliminates the shims, and no noise elimanator compaounds needed. They are a semi metalic ceramic compound. I did mine for the first time around a month ago
http://www.federalmogul.com/en/After...e/Thermoquiet/
I was totally amazed at the difference. Bedding is very simple 35 mph with a normal stop (as if coming to a stop sign) 5 times consecutively
Don't forget the mechanics wire for the calipers!!!
Old Aug 25, 2012 | 01:09 PM
  #48
wingnutks's Avatar
wingnutks
LOL too late. I only was going to change the rotors anyway, the pads are still good.
You safety wire your caliper pins?
Old Aug 25, 2012 | 01:58 PM
  #49
Dead2Fall's Avatar
Dead2Fall
Think he meant to tie them up while you work..
Old Aug 25, 2012 | 03:00 PM
  #50
Gone Fishin
Yup--thanks
Just keep these pads in mind for the future
