In A/C Hell
Old Aug 23, 2012 | 07:26 PM
austinbest's Avatar
austinbest
So it would only take about a half can and nothing more. It still did not kick on. Any of you dodge guru's have a way to start testing what can be wrong (based on the first post) w/o replacing everything one by one?
Old Aug 23, 2012 | 10:55 PM
joebaum's Avatar
joebaum
See if you are getting trigger @ comp , check for a good ground @ comp harness. If u are getting power @ comp then u shouldn't worry about fuses.
Old Aug 23, 2012 | 11:01 PM
joebaum's Avatar
joebaum
Just unplugg clutch give it power and a ground activating it, run truck and see if system performs . If yes diagnose your electrical problem if no diagnose your mechanical problem.
Old Aug 24, 2012 | 08:23 AM
austinbest's Avatar
austinbest
It has a good ground, i tested that prior to posting. I put a jumper to the clutch orange wire and the clutch jumped in, so i guess i can try that with it running too.
Old Aug 25, 2012 | 02:47 PM
austinbest's Avatar
austinbest
After unplugging the high sensor and AC and jumping it, it turns on, the pressure drops from like 100PSI to green while it is on, then when i take the jumper off it shoots back up. So this at least let me know the compressor is good. So as i was going to put the plug back on the high line sensor, i noticed it could be put on 2 different ways, bad design or maybe my plug is just worn out, not sure... I put the plug on the 2nd way (opposite of how i have had it) and sure as sh** it turned on, that is all it was!
So that is 2 stupid issues fixed (other was the windshield washer fluid light on, which i learned by searching here the sensor has to be vertical and mine was turned horizontal).
One last light and my truck is finally back to normal!
