Pinion nut torque help
Old Sep 17, 2012 | 09:55 PM
joebaum's Avatar
joebaum
Thankd
Old Sep 17, 2012 | 09:56 PM
joebaum's Avatar
joebaum
Thanks I mean
Old Sep 18, 2012 | 05:42 PM
wingnutks's Avatar
wingnutks
FWIW, I think you torque the pinion nut to 210lbs, no more, then check the pinion drag with the torque wrench. If the pinion drag isnt enough, add 10lbs of torque to the pinion nut and recheck pinion drag.
You dont want to start with over 210lbs of initial torque because you may over torque the nut and over crush the collar/over preload the pinion and then you have to start over with a new pinion crush collar.
Old Sep 18, 2012 | 06:29 PM
Dead2Fall's Avatar
Dead2Fall
210 is the n*m, 285 is the min ft/lb
Old Sep 18, 2012 | 06:31 PM
wingnutks's Avatar
wingnutks
You have that backwards.
Old Sep 18, 2012 | 06:44 PM
Dead2Fall's Avatar
Dead2Fall
According to the 04service manual I do not.
Old Sep 18, 2012 | 06:45 PM
Dead2Fall's Avatar
Dead2Fall
Derp, long day my bad
Old Sep 12, 2020 | 10:48 AM
Tyrell Gower's Avatar
Tyrell Gower
What is the carrier barring adjuster preload torque?
Old Sep 12, 2020 | 11:42 AM
What are you driving?
