stock stereo wiring
Old Sep 17, 2012 | 09:01 PM
RobsRedRacer's Avatar
RobsRedRacer
Default stock stereo wiring
Hey all,
My search came up empty handed...I've been trying to figure out my lack of stereo quality for a while...I have a sony HU and Polk Audio speakers in all 4 doors and get no bass out of the front doors and all bass and no vocals out of the rear doors....I put the stock unit back in and it sounded normal...front speakers had good bass and rear doors had vocals again...now the stock stereo harnass has two seperate connectors, one is the large connector that powers the speakers/etc...the other is a smaller connector with i think 4 wires to it? the aftermarket wiring harness does not connect to them, I was just wondering if anybody knew what those wires are used for? its a 06 Ram 4 speaker system with factory sat. radio
Old Sep 17, 2012 | 09:08 PM
Dead2Fall's Avatar
Dead2Fall
If you have the infinity stock audio, its the stock amp causing your troubles most likely. You will need an amplifier integration harness.
Old Sep 17, 2012 | 09:16 PM
RobsRedRacer
as far as i know it's not the infinity system...just the regular 4 speaker system...no infinity markings on the speakers or anything else i can tell
Old Sep 17, 2012 | 09:23 PM
Dead2Fall's Avatar
Dead2Fall
Sure it's not settings in the aftermarket HU? Not to insult you, but seen it happen before. Do you have another aftermarket HU you could pop in to try?
Old Sep 17, 2012 | 09:33 PM
RobsRedRacer
wish I did have another to try...I sat for hours over the past few weeks trying to figure it out..I had a buddy of mine that does radio installs and things look at it and play around with the settings and he couldn't figure it out either...I'm literally stump on what the cause of it is other than either 1) the unit I got is defective or 2) whatever that harness is it may be the cause of it...and I've been wanted to try to fix this before installing my sub/amp too so I don't have an even more messed up system
Old Sep 17, 2012 | 09:35 PM
Dead2Fall's Avatar
Dead2Fall
I was thinking bad unit. I'm not familiar with the 06 wiring, nor the factory sat radio. Could the 4pin connector be the sat radio connector?
Old Sep 17, 2012 | 09:42 PM
RobsRedRacer
i was thinking that but i wanted to see if anybody knew this for certain, and it wasn't like a bass/vocal leveler of some sort..i couldn't find anything through a search of what it was
Old Sep 17, 2012 | 09:45 PM
Dead2Fall's Avatar
Dead2Fall
Cav circuit function
1 a114 18gy/rd fused b(+)
2 - -
3 - -
4 x716 20gy/tn (hands free) left audio output
5 d55 20wt/or can b bus (+)
6 d54 20wt can b bus (-)
7 x154 18gy/yl (base) right front door speaker (+)
8 x156 18gy/lb (base) right front door speaker (-)
9 x155 18dg/lb (base) left front door speaker (-)
10 x153 18dg/yl (base) left front door speaker (+)
11 z514 18bk/lg ground
12 a114 18gy/rd fused b(+)
13 - -
14 - -
15 - -
16 x776 20tn/gy right audio output
17 x795 20dg common audio output
18 x205 18gy/lg (base) left rear speaker (+)
18 x51 20dg/db (premium) left rear speaker (+)
19 x295 18gy/dg (base) left rear speaker (-)
19 x57 20dg/or (premium) left rear speaker (-)
20 x296 18dg/gy (base) right rear speaker (-)
20 x58 20gy/or (premium) right rear speaker (-)
21 x206 18dg/lg (base) right rear speaker (+)
21 x52 20gy/db (premium) right rear speaker (+)
22 z515 18bk ground
radio c2 - gray 10 way
cav circuit function
1 x16 20dg/yl audio signal right (+)
2 x917 20dg audio signal common
3 - -
4 x510 18dg/lb vdo-aux audio right
5 x916 20gy/or sdars audio return
6 x17 20dg/or audio signal left (+)
7 x910 18gy/dg aux audio return
8 x511 18gy/lg vdo-aux audio left
9 x521 18gy/lb vdo-aux audio left 2
10 x522 18gy/db vdo-aux audio right 2
dr 8w-80 connector pin-outs 8w - 80 - 103
receiver-satellite (slt+/srt) - black 12 way
1 x17 20dg/or audio signal left (+)
2 - -
3 - -
4 z960 18bk ground
5 - -
6 a114 18gy/rd fused b(+)
7 x16 20dg/yl audio signal right (+)
8 x917 20dg audio signal common
9 - -
10 - -
11 d55 20wt/or can b bus (+)
12 d54 20wt can b bus (-)
With the locking clip to the top and the connector facing you, top row is "1 - 11" bottom row is "12 - 22"
Could always take the dive, cut the harness and hardwire it all, but I doubt the harness is your issue.
Old Sep 17, 2012 | 09:48 PM
RobsRedRacer
thanks a lot, i'll have to look to see if any of this matches what i have
btw where do i find this if i need to look it up again in the future?
Old Sep 17, 2012 | 09:51 PM
Dead2Fall's Avatar
Dead2Fall
http://www.4shared.com/file/wP7PvwlG...ce_Manual.html
Click the blue rectangle with "download now"
On the next page click the "free" button with the 20sec timer above it.
