miss fire
Old Sep 19, 2012 | 08:02 PM
Ahizzle36's Avatar
Ahizzle36
Default miss fire
i have a cylinder that is miss firing i believe im not %100 but im %80 percent sure my truck will jerk every few seconds when im crusing around 1400 rpms and the jerk starts in the motor and goes all the way back to the rear end im not sure ifim right though i was just hoping to get some thoughts or ideas on how to fix this or check to see what my problem is thanks.
Old Sep 23, 2012 | 09:37 PM
jasonw's Avatar
jasonw
Site Moderator
For future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Sep 24, 2012 | 08:49 AM
p38251's Avatar
p38251
When was the last time you did a tune up? throttle body cleaning. pcv. Start simple.
Old Sep 24, 2012 | 11:00 AM
willdikem66's Avatar
willdikem66
Any codes? Are you losing water?
Old Sep 24, 2012 | 09:57 PM
Ahizzle36's Avatar
Ahizzle36
i keep it pretty tuned up most of the time and i always change the oil on time i clean my air filter about once every two weeks and run engine cleaner through it pretty often. and i only had one code that was an air flow code about something i dont exactly remember but i changed the part out but the code still shows up.
Old Sep 25, 2012 | 11:00 AM
willdikem66
Well if you changed the part and you still have the code you either didnt reset your PCM or havent Fixed the problem.
Do the Key Trick and find out the code, Let us know what it is.
Cleaning You Throttle Body Like P38251 said is a good start and it very simple.
You also never answered my question if it is losing water????? This could be a problem.
Old Sep 27, 2012 | 06:37 PM
Ahizzle36's Avatar
Ahizzle36
no im not losing any water and i just checked for codes and now i dont even have a check engine light but i still have the problem should i just start with new plugs?
Old Sep 27, 2012 | 09:51 PM
willdikem66
Yes start simple
