It just busted coolant all over it's self!
Old Sep 27, 2012 | 07:18 PM
  #31
Kevno6's Avatar
Kevno6
my friend did the work but getting head rebuild cost me 300 for both. I would say if you ever overheated the truck the chances of having a warped are good. I was losing antifreeze for years. 2 years ago truck overheated and caught up with me this year with a misfiring plug.
Posted from Dodgeforum.com App for Android
Old Sep 27, 2012 | 07:28 PM
  #32
Kevno6's Avatar
Kevno6
as far as the vacuum sound or metal clatter I don't know if that's a symptom of a bad head.
Old Sep 27, 2012 | 09:53 PM
  #33
willdikem66's Avatar
willdikem66
Most likely vacuum
Old Oct 11, 2012 | 11:38 PM
  #34
milkman82's Avatar
milkman82
Default So far good
Sorry to beat a old post but, I just wanted to update everybody that everything has been doing great!
Even the coolant level has not dropped at all since I refilled it after the flush... I would assume this is a good sign for the heads correct? I know a cylinder compression check is the best bet. I have just been really busy and actually today was the first day I remembered to check the reservoir for low levels.
I still swear I hear and vacuum leak and a clatter. Starting to believe that clatter is actually the slack adjusters for the timing chains? In a way that perhaps the chains are what I am hearing?
Thanks again guys!
Let me know if any of you replace that radiator and have questions! Will be happy to answer! Just remember to use the coolant with HOAT additive!
