Leaf spring/ubolt torque specs???
Old Oct 2, 2012 | 04:07 PM
chris015's Avatar
chris015
Default Leaf spring/ubolt torque specs???
Doing the leafs on my 03 2wd regular cab. I guess the specs need to be right on these. I need the torque specs on the 2 main bolts and then the u bolts. Also,anyone know the exact size u bolts i will need? Im wanting to get them before i remove the old ones. Thanks
Old Oct 2, 2012 | 05:01 PM
willdikem66's Avatar
willdikem66
The service manual in Weeds sig tells everything you need to know, Download it
I just relaized you have a 03 give me a second and i will look it up
Old Oct 2, 2012 | 05:17 PM
willdikem66
DESCRIPTION N·m Ft. Lbs. In. Lbs.
Shock Absorber
Lower Nut
135 100 —
Shock Absorber
Upper Nut
135 100 —
Spring Clamp U-Bolts
Nuts
149 110 —
Spring
Front & Rear Bolt & Nut
163 120 —
Spring
Spring Rear Shackle Nuts
163 120 —
Jounce Bumper
Bolts
40 30 —
Auxialiary Spring Bumpers
41 30 —
willdikem66
Pretty much 110 ft lbs for U bolt
Old Oct 2, 2012 | 08:06 PM
chris015's Avatar
chris015
thanks,now would anyone know off hand what size they are?
Old Oct 3, 2012 | 10:30 AM
willdikem66
Stick a couple of sockets on there it wont take you long to find out
Old Feb 22, 2021 | 06:33 PM
Aaron Maurer's Avatar
Aaron Maurer
they are 21mm
Old Feb 22, 2021 | 07:14 PM
Alex Medeiros's Avatar
Alex Medeiros
Lmao he hasn't logged in since 2014...
Old Feb 23, 2021 | 09:12 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Originally Posted by Aaron Maurer
they are 21mm
