Do I need a new tranny?
Old Oct 8, 2012 | 07:47 PM
looka's Avatar
looka
Default Do I need a new tranny?
2006 Hemi:
Throwing codes:
P0700-Transmission Control
P0734-Gear ratio error in 4th
P0735-Gear ratio error in 5th
P1790-Fault immediately after shift
Truck shifts violently. Now in limp mode. Had tranny serviced less that 2 months ago.
What do you think?
Old Oct 8, 2012 | 08:00 PM
dlyter09's Avatar
dlyter09
Take it back to whoever did your service and make them fix it... They obviously fudged something up.
Old Oct 8, 2012 | 08:06 PM
looka's Avatar
looka
I did the tranny service myself. Drained the pan, replaced the filters and refilled. I've done a lot of drain and refills on trannys before so that's not the issue.
Old Oct 8, 2012 | 10:49 PM
HemiLonestar's Avatar
HemiLonestar
Did you get the replace the ring on the big flat filter where it goes into the VB?
Old Oct 8, 2012 | 10:58 PM
looka's Avatar
looka
Yeah. The ring came with the new filter.
Old Oct 9, 2012 | 02:01 AM
abarmby's Avatar
abarmby
That's usually the only thing you can do wrong when doing a fluid drop in these trannys.
That and stripping a pan bolt lol.
That o ring must be seated squarely and fully.
Plus it must not be pushed in by using the new filter.
Al.
Old Oct 9, 2012 | 06:42 AM
loflyer2's Avatar
loflyer2
When did you do the tranny service? There is an art to installing the flat pan filter correctly. It should be flush to the tranny body before putting the screw in. It plugs directly into the tranny pump and if the filter is even a little cocked you will get air in the system and the 0700 code.
Old Oct 9, 2012 | 07:17 AM
abarmby's Avatar
abarmby
Another symptom I've read about when installing the flat filter and o ring incorrectly in one of these transmissions is, stalling.
Al.
Old Oct 9, 2012 | 11:46 AM
looka's Avatar
looka
Any other suggestions besides the filter? Or is that the only thing you guys can think of?
Old Oct 9, 2012 | 11:59 AM
willdikem66's Avatar
willdikem66
I hate to say, but if its not the filter, then a new tranny is prolly going to be your only fix
