A/C compressor squeals
Old Oct 18, 2012 | 05:52 PM
Window Shaker Ram's Avatar
Window Shaker Ram
Default A/C compressor squeals
i just replaced my water pump, t-stat, and serpentine belt but now my compressor squeals when i turn the a/c on maybe i got anti freeze on something?
Old Oct 18, 2012 | 09:53 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Maybe try spraying it good with carb or brake clearer and then a good silicon lubricant
Old Oct 19, 2012 | 11:23 AM
Window Shaker Ram
just gave that a try, it cleared up for almost a minute then started again... is there bearings that maybe arent packed so good anymore?
Old Oct 19, 2012 | 02:49 PM
Izero's Avatar
Izero
if it persists for more than 300 miles the bearings might be shot... are you running the A/C when it squeals? or it squeals no matter what?
Old Oct 19, 2012 | 03:35 PM
Gone Fishin's Avatar
Gone Fishin
Buy a new belt, use brake cleaner to clean all the pulleys, then install new belt. Once the belt gets impregnated with antifreeze, oil, grease, etc. it's nearly impossible to really clean the offending chemical out without soaking the belt in chemicals that will break the belt down and ultimately destroy it earlier than normal
