Please help!!!!!! Driving me nuts
Old Oct 21, 2012 | 08:49 PM
Wilson01960196's Avatar
Wilson01960196
Default Please help!!!!!! Driving me nuts
Heyy..i am nee to the forum and hope i am doing this right..i have a 2006 ram 1500 4x4 5.7l hemi..ever since i bought the truck my speedometer seems to "lag" at times..ill be accelerating and itll randomly freeze for a brief moment than keep going..when it does freeze my turn signals freeze on the cluster to..lights on the outside continue to work fine but it freezes on the cluster..wgen it is colder out like below 45 it works perfectly!
Old Oct 21, 2012 | 08:51 PM
Wilson01960196
I have also replaced the input and output speed sensor in the transmission..drivee side hub..and the sensor on the rear dif. And also a brand new cluster but yet no fix yet.
Old Oct 23, 2012 | 11:20 AM
DodgeCACares's Avatar
DodgeCACares
Wilson,
I can honestly say I've never heard of this.
Now, I see you've already replaced the cluster but was it a new, used or reman. part? Because it seems as though it may be the issue.
I highly recommend getting your 1500 in to your local dealer to get this investigated as it may just need a flash.
Old Oct 26, 2012 | 09:34 PM
Wilson01960196
Originally Posted by DodgeCACares
Wilson,
It was a brand new cluster and its doing the same exact thing as it did with the old one except as soon as i plugged it in my abs and brake light came on..never did that on the old one!
Old Nov 2, 2012 | 09:42 AM
DodgeCACares
Wilson,
Any new updates for this issue? As previously mentioned, it's not something that I've heard of and you may want to have the concerns diagnosed by your Dodge Dealer.
If you need any assistance feel free to PM me.
Old Nov 3, 2012 | 12:09 PM
Wilson01960196
Wilson,
I have not took it to the dealer bc i feel like there is jus a bad ground somewhere in the cab..if its cold outside and i leave my heater off it works fine but when i turn the heatee on inside once it gets warm in the cab it starts doing it again..worse the hotter it gets in the cab
Old Nov 4, 2012 | 07:09 PM
lxman1's Avatar
lxman1
Site Moderator
Check the ground under the dash in the pedal frame area.
Old Nov 4, 2012 | 07:59 PM
p38251's Avatar
p38251
It is possiable the truck needs a re-flash. Some of the other manufactors require a re-flash when the cluster is replaced.
Old Nov 5, 2012 | 07:26 AM
Wilson01960196
I thought about the reflash too but it does the same exact thing as it did with the old cluster..wouldnt something change with the new one if it needed reflashed? And i still cant understand why it works when its cold in the cab and doesnt when it warms up
Wilson01960196
Yep already cleaned it with a wire brush
