'02 Ram 4.7 Heat
I did the core when I had my 02. I too, received the wrong core the first time, and the second time the core looked wrong, but the inlet/ outlet pipes can be turned. When I got it the pipes lay flat, parallel to the core but they can be turned into position.
Yes, it took care of the problem. I also installed a wye strainer in the heater supply hose. Put about 50 miles on it, and inspected it. Caught a few pieces of crap.
I also cut open the supply side of the core, using a cut off wheel. Ignore the silver shrapnel, that's from the cut. Note how small the passes are, and, note the debris found.
