Replacing wheelbearing/hub 2005 1500
Old Nov 21, 2012 | 03:44 PM
joeyb3's Avatar
joeyb3
Default Replacing wheelbearing/hub 2005 1500
I am having alot of trouble with replacing my front wheel bearings..I have everything apart and trying to seperate drivers side drive axle. Does anyone have a trick for this? I have watched numerous videos and they just pry it out of the housing but mine is not budging..Am I doing something wrong?
Old Nov 26, 2012 | 06:42 PM
jasonw's Avatar
jasonw
Site Moderator
For future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Nov 26, 2012 | 08:22 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site. Those 4wd's can be a PITA sometimes and more so if you live up north
Old Nov 27, 2012 | 08:01 AM
p38251's Avatar
p38251
Make sure you put anti-seize on the splines before you put it back together. It will save you from this problem later on. You may need to hit the end on the cv shaft with a hammer to get it free.
Old Nov 27, 2012 | 12:26 PM
HemiLonestar's Avatar
HemiLonestar
A bfh.
Old Dec 3, 2012 | 09:42 AM
jleonard's Avatar
jleonard
I rented a slide hammer from Autozone to get mine out. Return the hammer and they return your cash. Even with it the job was a pita.
Old Dec 3, 2012 | 10:13 AM
Izero's Avatar
Izero
Probably rusted on there pretty good... get as much liquid wrench (or w/e brand works for you) in there as possible to help loosen it up..
A slide hammer works well.
Old Dec 3, 2012 | 08:51 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
This guy joined the site and the 21st, made a post and hasnt come back since
