Is there anything I should worry about when switching from conventional to synthetic?
Old Nov 30, 2012 | 08:18 PM
CodeBlox's Avatar
CodeBlox
Default Is there anything I should worry about when switching from conventional to synthetic?
I'm changing my oil tomorrow and would like to use synthetic oil. Last few oil changes were conventional. Will there be any harm in doing this? Can I do all 7 quarts synthetic or do I need to mix? This is a 2007 Dodge Ram 2500 HD
Old Nov 30, 2012 | 08:46 PM
MikeHTally's Avatar
MikeHTally
It's OK to mix, switch back and forth, whatever. As long as you use the proper viscosity (5W-20), you'll be fine. As for any advantages of synthetic over dino oil, meh. I use synthetic only in my Mazda, 'cause o' the turbo.
BTW, pour in five quarts and check the level. You likely will not need the full seven quarts.
Old Nov 30, 2012 | 09:17 PM
08HEMI1500's Avatar
08HEMI1500
I haven't had any problems since my switch over. I usually put around 6 quarts in to fill it to the safe area. Although recently it seems that I've been losing oil slightly. Had to top it off a couple weeks ago.
Old Dec 1, 2012 | 08:00 AM
dirtydog's Avatar
dirtydog
Moderate User
No worries. If you have some oil left at the bottom of your pan that you are worried about, they do mix as stated, as long as they are the same viscosities. 90%Synthetic and 10% conventional residual is still synthetic in my book..haha
Old Dec 1, 2012 | 09:19 AM
scwpd's Avatar
scwpd
Just make sure you keep an eye on the level as a lot of people report a loss of oil for the first change or two after the switch
Old Dec 1, 2012 | 09:21 AM
Gone Fishin's Avatar
Gone Fishin
You will probably want to check the condition of the first change out, unless you've been running synthetic most of the time, as the synthetic oil will dissolve the buildup very quickly and deposit in your pan. As soon as it looks like conventional oil that is ready to change, change out the synthetic-------may seem expensive, but a plugged oil pickup is far more problematic to deal with and can in the extreme get kinda pricey too. After the second change, depending on how crudded up the engine is to begin with, you'll be golden to go full drain cycles.
Old Dec 1, 2012 | 03:59 PM
CodeBlox's Avatar
CodeBlox
Should this be OK to use?
http://www.walmart.com/ip/Mobil-1-5W...l-1qt/16767828
Old Dec 1, 2012 | 05:47 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sure, but if you buy it at Walmart, they usually have 1gal size bottles that will some you a few coins
Old Dec 1, 2012 | 06:05 PM
CodeBlox's Avatar
CodeBlox
Ended up getting 7 single quart bottles... They had the 5qt bottles in everything but 5w20. Will change tomorrow. Thanks guys!
Old Dec 3, 2012 | 01:08 AM
sabin420's Avatar
sabin420
I never recommend combining synthetic and conventional or mixing weights. But either can be done. Mixing weights is not an issue as the weight of the oil only describes it's viscosity at high and low temperatures. The only chemical difference in weights is the amount thinner or thickener they use in the oil to reach the desired viscosity. (thinner weights for winter, thicker for summer) Also, if you got a slight burning off of oil in the combustion chamber due to age and wearing valve guide seals, I suggest using a thicker oil to reduce this oil burn off.
Ex: 5w30 is thinner (lower viscosity) at both extremes than 10w40.
But synthetic and conventional are two separate chemical makeups making it a far more riskier than different weights. Always use all of one kind or the other on oil changes and you can go back and forth between the two if you like. It will cause problems if you swap between the two EVERY oil change.
You should be fine when changing over from conventional to synthetic. Just be sure to keep checking that oil level and I suggest an early 2nd oil change on the synthetic. After about the 3rd or 4th oil change, you shouldn't have any noticeable residue from the conventional in the engine anymore and in the clear. I don't see you having any problems with what you are doing.
