Rear Defrost?
Old Dec 21, 2012 | 06:37 AM
  #31
JWACGB's Avatar
JWACGB
Will do. It figures once I spent the money to make it work, the thing won't fog over. Before I got it wired up, just about every morning it was fogged over. Oh well. On to the next project on my truck.
Old Dec 21, 2012 | 09:52 AM
  #32
Izero's Avatar
Izero
well then you might have tapped into constant power so it might always be on, which is not good.
Get a multimeter and make sure you have 0.00V from the positive lead to ground at the window connector, with the switch and truck turned off....
Old Dec 21, 2012 | 06:37 PM
  #33
66three83's Avatar
66three83
Originally Posted by Izero
I've never had my back window fog up ever.... let us know how it works out
I know!! That's exactly what I was thinking!!
Old Dec 22, 2012 | 09:16 AM
  #34
JWACGB's Avatar
JWACGB
Will do. I checked with my test light when I was installing. It wasn't getting power until I turned the ignition switch on and flipped the switch. Forgot all about my voltage meter. Will test it with that as well. Thanks for the tip.
Old Dec 23, 2012 | 03:49 AM
  #35
JWACGB's Avatar
JWACGB
I checked with my meter. Showing 0.00 when ignition and switch are off. Showing 7.58 when key turned to run and switch on. Showing 9.79 when truck cranked and switch on.
