water pump bad!!
Old Dec 16, 2012 | 12:49 PM
catawissarocket's Avatar
catawissarocket
Default water pump bad!!
Well went out side this morning to check my oil and i see anti freeze dripping from area of the water pump. so i went to autozone and bought a new one. was going to do it myself but decided not to being im not to mechanically inclined.. according to the directions i could mess it up if not done properly . i know every garage works and charges differently but need an idea what it roughly would cost to do? like i said i have a new pump already.. thanks guys.. dodge forum has helped me alot..
shawn
Old Dec 16, 2012 | 01:10 PM
catawissarocket
Oh, and i think its in the early stages, no overheating and no squeeling. if i didnt pop the hood i would't never know about it. but its sweeping slighty down the front of the engine block.
Old Dec 16, 2012 | 01:32 PM
catawissarocket
hopefully i can get away with driving for afew days. i need to get to work, about 10 miles away.but i will be calling the garage tomorrow.. what you guys think??
Old Dec 16, 2012 | 01:47 PM
abarmby's Avatar
abarmby
Well when my 03 Hemi water pump went the other month, it started as a weep then within 1/2 a mile there was a torrent of coolant leaking out.
Not all I guess would be exactly like mine but, it's not a risk that I'd be taking by driving to work for a few days until I got things sorted.
If yours is a 4.7, coolings an issue anyway. So I definitely would not be taking the risk!
Just my humble opinion of course.
Al.
Old Dec 16, 2012 | 03:15 PM
loflyer2's Avatar
loflyer2
I doubt any shop will install customer-supplied parts. You'll probably have to return the pump. Really though, you are better off using the shop's parts because you can go back to them for any problem. The shop won't back parts that you supply.
Old Dec 17, 2012 | 01:44 PM
nateroach's Avatar
nateroach
Depending on the location of the leak you could be looking at a failing gasket. that was the case on mine. It would only leak when it was cold out and the gasket would shrink just enough to weep antifreeze.
also the replacement isn't that bad. once you get your fan, belt and hoses off, it's pretty smooth sailing.
best of luck with the replacement OP
Old Dec 17, 2012 | 09:03 PM
scwpd's Avatar
scwpd
Many shops will install customer supplied parts even oil change places will change your oil even if you provide you're own oil and filter they will just charge labor if I have to take my truck to a shop for work I'd rather supply my own parts instead of them getting the cheapest thing they can find just call a few shops and get some quotes on the labor since you all ready have the pump
Old Dec 19, 2012 | 05:09 PM
catawissarocket
All done.. good as new. thanks for the replys guys..
