2004 manual 4x4 shifter indicator light
Old Dec 17, 2012 | 10:24 PM
fj5gtx's Avatar
fj5gtx
Default 2004 manual 4x4 shifter indicator light
The indicator on the dash isn't doing its job anymore, I read that there is a switch on the transfer case - can any give me a picture or describe where that switch is on the transfer case? Figured pull the harness and ground the wire to see if the indicator lights up is a good test to see what I need to do (tear into the cluster or replace the switch).
Thanks!
Old Dec 18, 2012 | 12:54 PM
mitchn06's Avatar
mitchn06
4x4 light
scan through that once
Old Dec 18, 2012 | 06:45 PM
5.7Drew's Avatar
5.7Drew
http://www.factorymoparparts.com/5134375aa.html
Old Dec 18, 2012 | 06:47 PM
5.7Drew's Avatar
5.7Drew
i need to order one to but here its only 25 and u dont have to mess with the stealership
Old Dec 18, 2012 | 08:24 PM
fj5gtx's Avatar
fj5gtx
Default test your switch to see if its bad before tossing $ at it
So the link was helpful, in that it made me go look at a 2004 manual.
I found good info and then uploaded the following information to my album:
1. a picture of the connector.
2. a depiction of exactly where this switch is located
3. the resistance values you should see when the shifter is located in each position.
Should be easy to test if you have a digital multimeter.
Enjoy!
https://dodgeforum.com/forum/members...ase-17828.html
Old Dec 18, 2012 | 08:54 PM
fj5gtx's Avatar
fj5gtx
That price is prior to shipping... I checked a couple online places I've used in the past, on small value parts its actually cheaper to go to the dealer and pay retail(I drive past one on the way home from work). Plus you have it in your hand, like right now.
But big $ stuff, online is the way to go.
Old Dec 18, 2012 | 09:10 PM
5.7Drew's Avatar
5.7Drew
i didnt even think about the shipping. and yeah its nice to get it in hand right away
Old Dec 18, 2012 | 11:27 PM
Radam3's Avatar
Radam3
I had the same issue when I first bought my truck. Previous owner told me light didn't work but 4x4 worked just fine...
Went to dealership and bought said part. I wanna say it was under 30 bucks, it's been a while... Ten minutes under the truck change out switch, and light worked again.
Very easy fix
Old Dec 21, 2012 | 11:17 PM
Wanderer's Avatar
Wanderer
Easy fix. Here in the northeast, it is common failure. Remeber to check the rubber O ring.
