2004 hemi Just Started Using Oil
Old Dec 27, 2012 | 03:56 PM
199NT's Avatar
199NT
No gasket that could be cuasing the problem? My hose leading to the breather is fine but I did use an after market pcv vaulve. This thing blows my mind!
Old Dec 27, 2012 | 08:36 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Aftermarket PCV valves have the tendency to be looser tolerances than the factory ones, allowing more oil through and into the intake manifold. It's at least something to look into. The factory ones are like 7 or 8 bucks.
Old Dec 29, 2012 | 08:35 PM
Wanderer's Avatar
Wanderer
I agree that a quart per thousand miles is excessive, especially if it comes on quickly. I have 90K and change my oil before it's down a quart, between 5000 and 6000 miles. Chrysler states that 1 quart/2000 miles for the first 50,000 miles is acceptible and then it is acceptible to got to s**t, quart/750 miles. Below is the current TSB form Jeep, but it is the same across all product lines
Service Bulletin 09-001-12 Engine Oil Consumption Guideline 2012-2013
Service Bulletin NUMBER: 09-001-12
GROUP: Engine
DATE: June 27, 2012
SUBJECT: Engine Oil Consumption Guideline
JEEP MODELS INCLUDED:
2012 - 2013 (JK) Wrangler
2012 - 2013 (J3) Wrangler (CKD)
2012 (K1) Cherokee (CKD)
2012 (KK) Liberty
2012 - 2013 (MK) Compass/Patriot
2012 - 2013 (W2) Grand Cherokee (CKD)
2012 - 2013 (WK) Grand Cherokee
NOTE: This bulletin applies to all Chrysler Group LLC vehicles equipped with
gasoline engines, except SRT and Viper models or vehicles equipped with
Diesel engines.
Oil Consumption
The accepted rate of oil consumption for engines used in the vehicles listed above is 0.946 liter (1 qt.) in 3,200 km (2,000 mi) for the 1st 80,467 km (50,000 mi). For vehicles with more then 80,467 km (50,000 mi) the acceptable oil consumption for engines is 0.946 liter (1 qt.) in 1,207 km (750 mi).
CAUTION: This above rate only applies to personal use vehicles, under warranty, that are driven in a non-aggressive manner and maintained in accordance with the appropriate maintenance schedule,
CAUTION: This rate does not apply to vehicles that are driven in an aggressive manner, at high RPM, high speeds, or in a loaded condition (for trucks).
See ‘Causes for Oil Consumption’ below. Oil consumption for vehicles driven under these conditions will be higher and may include Fleet and Commercial customers.
There are many factors that can affect a Owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Inspect each condition listed below prior to determining if the vehicle in question has abnormal engine oil consumption.
If abnormal oil consumption is suspected, refer to the detailed diagnostic procedures available in DealerCONNECT> TechCONNECT under: Service Info> 09 - Engine> Diagnosis and Testing - Oil Consumption Test And Diagnosis.
